https://docs.viktor.ai/docs/welcome
When searching for something, you often get multiple search results for the same item, only each result points to a different SDK version.
E.g. if you search for table, you get the current results. Each TableMethod points to another SDK version
I only expect the see 1 result for the latest version. If you want to search for a specific version, maybe add v=xx.x to you search query but I don’t expect to see so many doubles for different version.
It is rather annoying to get so many search results. It is also not the case that the first result is the latest SDK version but it is in random order. This behavior makes searching difficult.
