Multiline TextField
At the moment I use textfield to allow the user to enter some text.
However I would like to have a default Text input for comments to be place to be a multiline field.
Just like the TextField I am using here to create this topic. Is it possible to have an argument that allows a default size or maybe including a scroll bar for TextFields?
Hi Johan,
I think you are looking for a TextAreaField? this allows you to input text with multiple lines.
I’m not sure you can set a default size, but you can add a default text to influence the initial size of the field. Does that solve your needs?
kind regards,
Paulien
Hi Paulien,
I didn’t know this existed. I have used it and with a default line break it works just fine. Thanks for the fast reply
FYI we try to keep this page in the docs up-to-date with a visual representation of all available fields:)
