I’ve spotted a small mistake, the code for the U72
To replace update_properties, this is sugested:
- entity.update_properties(new_params_subset)
- params = entity.last_saved_params
- new_params = params.update(new_params_subset)
- entity.set_params(new_params)
but the params.update() doesn’t return the new_params, rather is updates the params itself.
This causes an error at set_params as ‘new_params’ is null or empty at that time. I fixed it by sending params here, and that worked.
So either I did something differently or you might want to adjust that in the docs.
