Not possible to add description to load combinations in Scia (LC and NLC). Not critical but it’s an easy addition and helps for the quality of the Scia model.
Thanks in advance! (no hurry, but its 10-20 min work max i assume)
def create_load_combination(self, name: str, load_type: LoadCombination.Type, load_cases: Dict[LoadCase, float]) -> LoadCombination: ...
def create_nonlinear_load_combination(self, load_type: NonLinearLoadCombination.Type, load_cases: Dict[LoadCase, float], *, name: str = ...) -> NonLinearLoadCombination: ...
Add description: str to both methods
None
