Hey,
I found in the docs how to merge two PDF file with merge_pdf_files for which two different context managers are defined. How would this principle generalize for an undefined number of files to merge?
As you can see in the function signature, *files, there is an asterisk before files, this means you can use an arbitrary number of files as input.
Handling multiple context managers can be done by using an ExitStack: contextlib — Utilities for with-statement contexts — Python 3.7.12 documentation
In code this could look something like the snippet below:
def download_merged_pdfs(params, **kwargs) -> DownloadResult:
from contextlib import ExitStack
files = 10 * [File.from_path(Path(__file__).parent / "dummy.pdf")]
with ExitStack() as stack:
merged = merge_pdf_files(*[stack.enter_context(f.open_binary()) for f in files])
return DownloadResult(file_content=merged, file_name="merged.pdf")
Thanks Raoul, this is exactly what I was looking for!
