Loading screen doesn't show
SDK: v13.0.0
Platform: v2022.x.x
Python: v3.9.0
Isolation mode: venv
Our Viktor app use to show the loading screen when the download button was pressed, running a script. Now no loading screen appears, but the app still runs as expected.
For the loading screen to pop up when clicking the download button
Context
We thought it could be to do with the try statements, or maybe how we’ve formatted the error statments, but changing that hasn’t fixed the issue. The loading screen is important to let the user the script is working, as the script can take several minutes to run.
Code:
from viktor import ViktorController, UserException
from .parametrization import Parametrization
from .BGS_helper import *
from viktor.views import MapPoint
from viktor.views import MapResult
from viktor.views import MapView
from viktor.views import MapPolygon
from viktor.result import DownloadResult
from viktor.core import File
from shapely.geometry import Polygon
from datetime import datetime
import urllib3
import json
    label = 'Scraper Entity'
    # Duration guess allows to write a new address avoid the app running every typing.
    @MapView('Map view', duration_guess=4)
    def get_map_view(self, params, **kwargs):
        This function returns a map location based off an input marker
        Parameters
        coordinats : Points from the search_location function,
        defined by the user
        Returns
        Updates the map view to the desired location
        features = []
        coordinats = BGS.search_location(params.address)
        marker = MapPoint(coordinats[0], coordinats[1], icon=None)
        features.append(marker)
        if params.polygon:
            features.append(MapPolygon.from_geo_polygon(params.polygon))
        return MapResult(features)
    def download_file(self, params, **kwargs):
        This function runs the BGS_Polygon_scraper script and returns a
        csv and PDFs of borehole information from the user defined polygon
        area.
        Parameters
        params.polygon : A user drawn polgon on the map view
        Returns
        A zip file containing a csv and PDFS of borehole information
        if params.polygon:
            eastings = []
            northings = []
            # Convert lat, lon points to eastings, northings
            for point in params.polygon.points:
                http = urllib3.PoolManager(1)
                try:
                    url = "http://webapps.bgs.ac.uk/data/webservices/CoordConvert_LL_BNG.cfc?method=LatLongToBNG&lat=%s&lon=%s" % (str(point.lat), str(point.lon))
                    resp = http.request('GET', url)
                    result = json.loads(resp.data.decode())
                    eastings.append(result["EASTING"])
                    northings.append(result["NORTHING"])
                except urllib3.exceptions.HTTPError as e:
                    raise UserException(e.reason)
            # Test to see if shae is valid
            if bool(eastings) and bool(northings):
                # Convert points to shapely polygon
                polygon_geom = Polygon(zip(eastings, northings))
                # Run methods
                XYZ = BGS.boreholes_from_polygon(polygon_geom)
                pdf_result = BGS.download_images(XYZ.image_paths)
                # Save csv of boreholes dataframe
                csv_result = BGS.polygon_to_csv(polygon_geom)
                data_time = datetime.now()
                time_stamp = data_time.strftime("%d-%b-%Y")
                file_name = f"{time_stamp}_Boreholes_{params.address}"
                zip_dict = {}
                zip_dict["boreholes_in_polyline.csv"] = File.from_data(csv_result)
                for pdf in range(len(pdf_result[0])):
                    zip_dict[pdf_result[1][pdf] + ".pdf"] = File.from_data(pdf_result[0][pdf])
                return DownloadResult(zipped_files=zip_dict, file_name=file_name + ".zip")
Thanks,
Charlie
Hi Charlie,
By setting the parameter longpoll=True on the DownloadButton you trigger the progress modal.
