While installing an app (venv version), something did not work whie installing shapely (v1.7.0). I restarted my pc, now the following messages show when installing my app:
SDK version: 13.1.0 Connector version: 5.13.0
Creating app specific install dir viktor-docs
Creating app specific install dir viktor-stubs
Creating app specific install dir signals
Creating virtual environment
Exiting because of an error: installation of the app failed
Before restarting my pc I got an error saying that shapely could not get installed due to go.dll (this definitely has a typo, writing this from memory).
I don’t think that is necessary. Just to make sure; the error occurs after Creating virtual environment is printed and you don’t see any pip related commands that the install of dependencies is happening?
Could you try to manually remove the venv folder from the app folder and after that manually creating the virtual environment. You can do that by opening a command prompt inside the app folder and executing the command python -m venv venv. Does this create the virtual environment folder without errors?
Trying powershell, I cannot create the virtual environment:
"Scripts\Activate.ps1 : File C:\Users\kt33\viktor-app-starter\APP\venv\Scripts\Activate.ps1 cannot be loaded because running scripts is disabled on this system. For more information, see about_Execution_Policies at https:/go.microsoft.com/fwlink/?L
inkID=135170.
At line:1 char:1
+ Scripts\Activate.ps1
+ CategoryInfo : SecurityError: (:) [], PSSecurityException
+ FullyQualifiedErrorId : UnauthorizedAccess"
This happens even when I have powershell opened as administrator. Would this mean our digital infrastructure does not allow activating .bat scripts?
Allright, the app can install now. However, when installing shapely the following error occurs:
Collecting shapely==1.7.0
Using cached Shapely-1.7.0.tar.gz (349 kB)
Preparing metadata (setup.py) ... error
error: subprocess-exited-with-error
× python setup.py egg_info did not run successfully.
│ exit code: 1
╰─> [10 lines of output]
File "<string>", line 2, in <module>
File "<pip-setuptools-caller>", line 34, in <module>
File "C:\Users\kt33\AppData\Local\Temp\pip-install-5c197azp\shapely_510bf7a2728142ad83582bd3c406cb77\setup.py", line 85, in <module>
from shapely._buildcfg import geos_version_string, geos_version, \
File "C:\Users\kt33\AppData\Local\Temp\pip-install-5c197azp\shapely_510bf7a2728142ad83582bd3c406cb77\shapely\_buildcfg.py", line 205, in <module>
lgeos = CDLL("geos_c.dll")
File "C:\Users\kt33\AppData\Local\Programs\Python\Python310\lib\ctypes\__init__.py", line 374, in __init__
self._handle = _dlopen(self._name, mode)
FileNotFoundError: Could not find module 'geos_c.dll' (or one of its dependencies). Try using the full path with constructor syntax.
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
error: metadata-generation-failed
× Encountered error while generating package metadata.
╰─> See above for output.
note: This is an issue with the package mentioned above, not pip.
hint: See above for details.
This was the error message mentioned earlier.
Using a newer versions of numpy and shapely solved the problem.
