Insert, items in text field
Hello,
I have a question about the text field. I want to use bullet points like in the documentations. But inserting enters or latex expressions as is recommended doesn’t work. Can anyone help me with this problem.
A link to the print screen [
Layout & styling - Style text using Markdown | VIKTOR Documentation
Hi Pim,
You can use the following snippet, make sure to stick to this indentation (i.e. no indents in front of each line):
class MyParametrization(Parametrization):
    info = Text("""
Please select the wing model below
- 2D: ...
- 3D: ...
    1. High AR ...
    2. Low AR ...
