Apperently Idea RCS v24 isn’t supported yet.
When is this available?
As our engineering department switched to v24 a few months ago.
Hi Johan, thanks for the request.
It is not yet planned, but we will take your request into account.
@khameeteman the same for Scia v24 btw.
Maybe it would be a nice batch for a single sprint. If you need any input, you know where to find me
I believe SCIA v24 should be working with the latest version of the worker. But please let me know if you run into issues.
@khameeteman okay the documentation should probably be updated than:
We will try it.
@Johan_Tuls we have just released worker v5.6.0 which works with IDEA v24!
@khameeteman thanks! We will update it next week.
Btw, i found out that with Scia v24 a default argument changed for the free surface load:
This argument cannot be adjusted in the sdk:"
Now the default is always valid at z=0. However in our case it should be “All” for example.
I shall also make a bug issue, but thought i’d share it as it seems to be part of a version upgrade.
