Hi all,
it is probably really simple, but I’m unable to get a DataView from a dataframe. I currently do DataResult(df), but this returns a TypeError: ‘numpy.ndarray’ object is not callable.
Thanks a lot!
Cheers,
Jelle
Hi all,
Thanks a lot!
Cheers,
Jelle
Hi Jelle,
The reason why your implementation does not work is because the DataView
accepts a DataGroup
object that holds a range of DataItem
objects, which you could further nest with DataGroup
objects. For more on the DataView
and how to implement it, refer here to the documentation:
If you simply want to visualize your DataFrame
object, I would recommend using the PlotlyView
, and create a plotly
table from a DataFrame
as is presented by this example:
Let me know if this was clear and helpful.
