Hi
I have a method that save some results to storage using Storage().set(...)
How do I test that the method saves the correct results, i.e. checks the input for Storage().set
Hi
Hello Thomas,
Welcome on the VIKTOR community forum!
In general, you can ‘mock’ objects within tests using Python’s built-in unittest.mock
library. You can patch
VIKTOR’s Storage.set
function and call assert_called_once_with
to test whether it was called with the desired input.
