I have a case where Excel-files are returned from a generic worker. Those files I want to add as child entities and store on storage.
I know how to create the child entities by the following method:
entity = API().get_entity(entity_id)
child_entity = entity.create_child(
entity_type_name="xxx",
name="xxx",
And I know how to store the file on storage by the following method:
storage.set(
key=child_entity.name,
data=File.from_data(output_file.read()),
scope="entity",
entity=child_entity,
But I don’t know how to connect the two methods, so the file is added correct to the child_entity. By using the above method for storage.set (using entity=child_entity
), no file is added to child_entity
I didn’t find any solution to my problem in the VIKTOR documentation, so I hope someone here can help.
Hi Mads!
Welcome to the community forum
I tested a similar functionality in a test app, and I could make it work.
I defined two entities.
Parent entity:
from viktor.api_v1 import API
from viktor.core import Storage, File
from viktor.parametrization import ViktorParametrization, ActionButton
calculation_btn = ActionButton("create entity with storage", "create_entity")
label = 'My Folder'
children = ['MyEntityType']
show_children_as = 'Table'
def create_entity(self, entity_id, **kwargs):
entity_type_name="MyEntityType",
name="test",
params={}
Storage().set(
data=File.from_data("hello"),
scope="entity",
Child entity:
calculation_btn = ActionButton("Get file", "get_from_storage")
viktor_enforce_field_constraints = True
label = 'My Entity Type'
def get_from_storage(self, **kwargs):
file = Storage().get(
key="test",
scope="entity",
print(file.getvalue())
The child entity is created successfully and a file is stored on the child entity.
Have you upgraded your SDK version with viktor-cli upgrade
and is the content of the stored file valid?
Let me know if you still get stuck.
