Hi, thank you for your prompt answers. Please find below an example to illustrate the situation (in the case of ‘isActive’). I can provide additional information or a real working example if necessary.
Context: the steps involved and the functions
# previous_step (prev) is an initialization step
previous_step = parametrization.Step('Previous Step',)
previous_step.standard = parametrization.OptionField(
'Standard',
options=[NDS_2018, NDS_2015, NDS_2010],
flex=FLEX_DEFAULT_VALUE,)
previous_step.unit_system = parametrization.OptionField(
'Unit system',
options=[IMPERIAL, METRIC],
# current_step (curr) is an input parameters step
current_step = parametrization.Step(
'Current Step',
previous_label='Previous Step ',
next_label='Calculate',
on_next=validate_user_inputs,)
# Functions for both with and without the proposal design
def is_NDS_2018_and_metric(params, **kwargs) -> bool:
"""Check if the previous step standard is NDS_2018 and unit_system is metric."""
prev = params.previous_step
return prev.standard == NDS_2018 and prev.unit_system == METRIC
def has_NDS_2018__fire_resistance_rating_metric(params, **kwargs) -> bool:
"""Check if fire_resistance_rating is set."""
curr = params.current_step
return (is_NDS_2018_and_metric(params, **kwargs)
and bool(curr.NDS_2018__fire_resistance_rating_metric))
def activate_NDS_2018__wood_blocking_metric(params, **kwargs) -> bool:
"""Returns True if fire_resistance_rating is set and element_hidden is True."""
and curr.NDS_2018__element_hidden_metric)
Without the attribute isActive
Parameter ‘NDS_2018__wood_blocking_metric’ would move depending on visible attribute.
# Parameters example without the proposal design
current_step.NDS_2018__fire_resistance_rating_metric = parametrization.IntegerField(
prefix='t',
ui_name='Fire-resistance rating',
suffix='minutes',
min=0,
visible=is_NDS_2018_and_metric,
current_step.NDS_2018__sides_exposed_metric = parametrization.OptionField(
ui_name='Sides exposed',
options=['Top', 'Bottom', 'Top and Bottom'],
visible=has_NDS_2018__fire_resistance_rating_metric,
current_step.NDS_2018__V_fire_metric = parametrization.NumberField(
prefix='$V_{fire}$',
ui_name='Shear force for fire resistance design',
suffix='kN',
min=0,
current_step.NDS_2018__wood_blocking_metric = parametrization.NumberField(
prefix='$t_{blocking}$',
ui_name='Wood blocking',
suffix='mm',
min=0,
visible=activate_NDS_2018__wood_blocking_metric, # The element would be hidden
With the attribute isActive
Parameter ‘NDS_2018__wood_blocking_metric’ would be grayed depending on isActive attribute.
# Parameters example with the proposal design
current_step.NDS_2018__element_hidden_metric = parametrization.BooleanField(
ui_name='Element is hidden',
default=False,
isActive=has_NDS_2018__fire_resistance_rating_metric,
suffix='kN',
min=0,
suffix='mm',
min=0,
isActive=activate_NDS_2018__wood_blocking_metric, # The element would be grayed
