I would like to know more about how I can integrate my Grasshopper scripts into Viktor. Can I have a custom instance of grasshopper with my desired plug-ins on it for the Viktor server to run? How would implementing this work?
Thanks,
Charlie
Thanks,
Charlie
Hi Charlie,
The Grasshopper and Rhino instances run on your own server.
It is possible to use whatever Grasshopper plugins you want to use, as long as you have them installed on your server. I assume you have inquired our Rhino / Grasshopper integration documentation?
I would advise you to follow these steps:
Hope that helps!
