I am trying to send an uploaded file to the worker, but I keep getting the following error:
2023-04-28 08:59:53.969 ERROR : Exception is raised
File “viktor_connector\connector.pyx”, line 295, in connector.Job.execute
File “viktor\core.pyx”, line 1920, in viktor.core._handle_job
File “viktor\core.pyx”, line 1905, in viktor.core._handle_job._handle_view
File “viktor\views.pyx”, line 1927, in viktor.views.View._wrapper
File “D:\viktor\EnergyAnalysis\app.py”, line 28, in displacement_plot
generic_analysis.execute(timeout=120)
File “viktor\external\external_program.pyx”, line 335, in viktor.external.external_program.ExternalProgram.execute
File “viktor\external\external_program.pyx”, line 337, in viktor.external.external_program.ExternalProgram.execute
File “viktor\external\generic.pyx”, line 81, in viktor.external.generic.GenericAnalysis._write_job_content
NotImplementedError
The code is:
def displacement_plot(self, params, **kwargs):
building = params.building
print(building)
# Generate the input file(s)
files = [
('building.txt', building)
#('input2.txt', file2)
# Run the analysis and obtain the output file.
generic_analysis = GenericAnalysis(files=files, executable_key="countdown", output_filenames=["figure.json"])
output_file = generic_analysis.get_output_file("figure.json")
figure = plotly.io.read_json(output_file, output_type='Figure', skip_invalid=False, engine=None)
return PlotlyResult(figure.to_json())
What am I doing wrong? How do you pass a file that has been uploaded to the web app? Thanks
