As a a user I want to be able to select parts of a geometry which are used for further calculations so that I don’t have to use a dropdown on the input side, which is a lot less user friendly.
I think this is relevant for the VIKTOR platform because (3d) models are frequently used and improved user friendliness will make it easier to adopt new tools
Using a dropdown + labels in the view
We started development on this feature. Current plans are:
- First start with selection on the
IFCView
- Extend this with selection on the
GeometryView
Will post updates on the feature here
I believe this is valuable for you @Tom_Nillesen, @Mike684
@RamiEvans This is something we’ve talked about as well, right?
We discussed this earlier as well @dgaspar So I thought that you might find it interesting to follow
We have released geometry selection on the IFCView.
visit the docs to learn how to make the interaction with your model more user friendly: Results & visualizations - 3D model | VIKTOR Documentation.
Next up is selection in the GeometryView, we are almost done with the implementation.
We have now also released geometry selection on the GeometryView!
This means you can now add selection for:
- IFC geometries
- gltf geometries (created by viktor.geometry or other source like
CADQuery)
- rhino3dm geometries coming from grasshopper
Learn more about it in the docs (this wrongly states the GeometryView does not yet work. it does!).
Interested to hear your opinions @Wichard , @Tom_Nillesen , @Mike684, @RamiEvans , @dgaspar
