Hi Everyone, I have one general idea to define some geometry in Map View (e.a. polygon - with coordinates and then use this polygon in Geometry View - 3D). Is it possible to integrate this two types of views together? So bring the map space to Geometry View? So axis in Geometry View will have map coordinates - e.a. make “Scene (3D) View” from Geometry 3D View.
Hi @Marian,
Welkom to the community.
Points you select on a map are points on a sphere. So they are ‘Spherical coordinates’. Spherical coordinates can be converted to cartesian coordinates using:
x = RADIUS * cos(geo_point.lat) * cos(geo_point.lon)
y = RADIUS * cos(geo_point.lat) * sin(geo_point.lon)
z = RADIUS * sin(geo_point.lat)
So using this you can draw some points (spheres) and lines (cilinders) in the 3D geometry view. Here is a VIKTOR example that does this:
from math import cos, sin
from viktor.geometry import Point, Polygon, Group, Sphere, Line, CircularExtrusion
from viktor.parametrization import ViktorParametrization, GeoPolygonField, ToggleButton
from viktor.views import MapView, MapResult, GeometryView, MapPolygon, GeometryResult
RADIUS = 6371 # km
geo_polygon = GeoPolygonField("Map Polygon")
label = 'My Entity Type'
@MapView("Map", duration_guess=1)
def map_view(self,params, **kwargs):
features = []
if params.geo_polygon is not None:
map_polygon = MapPolygon.from_geo_polygon(params.geo_polygon)
features.append(map_polygon)
return MapResult(features=features)
@GeometryView("Scene (3D) View", duration_guess=1, x_axis_to_right=True)
def geometry_view(self, params, **kwargs):
geo_polygon = params.geo_polygon
# convert GeoPoints (lat/long) to geometry points (x,y,z) and add spheres to the geometry view
points = []
geometry_objects = []
for geo_point in geo_polygon.points:
point = Point(x, y, z)
points.append(
point
# draw sphere at the points
geometry_objects.append(
Sphere(centre_point=point, radius=10)
# draw 'lines' between points
for point1, point2 in zip(points, points[1:]):
line = Line(point1, point2)
cilinder = CircularExtrusion(10, line)
geometry_objects.append(cilinder)
# draw line between last point and start point to close 'polygon'
CircularExtrusion(10, Line(points[-1], points[0]))
return GeometryResult(Group(geometry_objects))
In this example you can select an polygon on the map view. The polygon is then converted to a 3d object in the GeometryView
In the GeometryView, you can click the 3 dots and select ‘Center camera’ to get the polygon in view.
Is this wat you where looking for in 3d?
Hi @mweehuizen,
thank you a lot for your very fast response. I tryed to implement your solution in app and I understand to your idea. Your solution is transform coordinates from map service (global coordinates) to plane. I suppose, that map service in MapView used WGS84 coordinate system with some reference area (Auxilliary sphere, e.a.). I looked to console of web browser and it showed me some tile service hosted in viktor ai environment. Am I right with used coordinate/reference system of used map service?
My result is quite weird in Z coordinates, where Z dimension is not in plane (map area is not wide acording to sphere surface). I think I will need to implement some additional transformation calculation to get geometry in plane without distortion from global position system to plane reference. Or I do something wrong.
This is defined area in MapView (area of Prague - over 30 km in width):
And this is result in GeometryView:
Thanks @mweehuizen,
your idea was usefull for me. I found, that calss “GeoPolygonField” from your script returnes array of vertexes (.lon and .lat in WGS84 format EPSG: 4326). I changed your calculation formula and use conversion from EPSG: 4326 to EPSG: 3857 - which is WebMercator (AuxSphere) with coordinates X,Y:
from math import pi, tan, log
r = 6378137.0 # RADIUS
phi = geo_point.lat/180pi
lamb = geo_point.lon/180pi
x = r * lamb
y = r * log(tan(pi/4 + phi/2))
so service in MapView has EPSG:3857 but class attributes .lon, .lat returns coordinates in EPSG: 4326 and when you want to use its in GeometryView, its needed to convert it instead of that.
Result is without distortion:
Z coordinates map view seems dont offer
Thank you for your help.
Wow great solution.
I am not that familiar with al the different CRS available.
I was not aware that you wanted to transform the area into 2D (I kept it in 3D). Which looked a bit weird indeed. Bit great job with the transformation.
It might be nice to put the 2D shape in PlotlyView instead of the GeometryView. I finf that view nicer for 2D plots.
greetings,
Maarten
