Hi Support,
I am trying to start an application with the Geolib package. The application installs correctly, but when I try to run the application it gives the following error:
bavo6@LAP022036:~/viktor-apps$ ./viktor-cli-heijmans start HI-Paalapplicatie
2022-03-08 14:50:41.317 INFO : __ __ __ __ __
2022-03-08 14:50:41.318 INFO : \ \ / / | | | |/ /
2022-03-08 14:50:41.318 INFO : \ \ / / | | | ' /
2022-03-08 14:50:41.318 INFO : \ \/ / | | | <
2022-03-08 14:50:41.318 INFO : \ / | | | . \
2022-03-08 14:50:41.318 INFO : \/ |_| |_|\_\
2022-03-08 14:50:41.318 INFO : _______ ____ _____
2022-03-08 14:50:41.318 INFO : |__ __| / __ \ | __ \
2022-03-08 14:50:41.319 INFO : | | | | | | | |__) |
2022-03-08 14:50:41.320 INFO : | | | | | | | _ /
2022-03-08 14:50:41.320 INFO : | | | |__| | | | \ \
2022-03-08 14:50:41.320 INFO : |_| \____/ |_| \_\
2022-03-08 14:50:41.320 INFO : VIKTOR connector v5.9.1rc3
2022-03-08 14:50:41.320 INFO : VIKTOR SDK v12.9.0
2022-03-08 14:50:41.320 INFO : Loading SDK...
2022-03-08 14:50:43.684 INFO : Loading geolib...
File "<string>", line 1, in <module>
File "viktor_connector/connector.pyx", line 1480, in init connector
File "viktor_connector/connector.pyx", line 1433, in connector.main_continuous
File "viktor_connector/connector.pyx", line 296, in connector.import_geolib_modules
File "/usr/src/packages/geolib/__init__.py", line 8, in <module>
from .models import *
File "/usr/src/packages/geolib/models/__init__.py", line 3, in <module>
from .dfoundations import DFoundationsModel
File "/usr/src/packages/geolib/models/dfoundations/__init__.py", line 1, in <module>
from .dfoundations_model import DFoundationsModel
File "geolib/models/dfoundations/dfoundations_model.pyx", line 41, in init geolib.models.dfoundations.dfoundations_model
File "geolib/models/dfoundations/serializer.pyx", line 3, in init geolib.models.dfoundations.serializer
File "/usr/src/packages/jinja2/__init__.py", line 12, in <module>
from .environment import Environment
File "/usr/src/packages/jinja2/environment.py", line 25, in <module>
from .defaults import BLOCK_END_STRING
File "/usr/src/packages/jinja2/defaults.py", line 3, in <module>
from .filters import FILTERS as DEFAULT_FILTERS # noqa: F401
File "/usr/src/packages/jinja2/filters.py", line 13, in <module>
from markupsafe import soft_unicode
ImportError: cannot import name 'soft_unicode' from 'markupsafe' (/usr/src/packages/markupsafe/__init__.py)
Do you know how I can fix this?
