We are trying to upload a .stix file (D-Stability) and use it to parse with GeoLib.
If we try it locally it works just fine. But when we try to use a FileField. I can’t find a way to convert the FileResource to a workable local file with a corresponding Path to send to the Geolib:
Any idea what we could do?
@property
def d_stability_file(self) -> Path:
file: FileResource = self.get_param("d_stability_file")
new_file = file.file.from_url(file.file.source)
location = Path(__file__).parent / file.filename
with new_file.open() as r: # open in text-mode, so read -> str
new_file = File(path=location, data=r.read())
return Path(new_file.source)
We fixed it
@property
temporary_file = NamedTemporaryFile(suffix='.stix', delete=False, mode='wb')
temporary_file.write(file.file.getvalue_binary())
temporary_file.close()
return Path(temporary_file.name)
This should work I think, which doesn’t require creating a temporary file explicitly:
@property
file_resource: FileResource = self.get_param("d_stability_file")
return file_resource.file.copy().source # copies the File.from_url to disk (as a File.from_path) and return the path
It does make a local copy, but it looks like it’s not possible to get all the information out of all the nested json files within the stix file using this option.
Error message:
Couldn't find required file at C:\Users\CA0AE~1.RAS\AppData\Local\Temp\tmpijua6k58\soilcorrelations.json
I suppose this is caused by the missing ‘.stix’ extension. The created temporary file with .copy()
has no extension. Renaming the path might work:
@property
path = file_resource.file.copy().source # copies the File.from_url to disk (as a File.from_path)
new_path = path + '.stix'
os.rename(path, new_path)
return new_path
