Force field to have a value
As a developer I want to ensure communicate clearly to the user that a field should have a value in a simpler way than now, which requires setting up UserErrors, InputValidations and the like, so that developments are easier and cleaner.
I think this is relevant for the VIKTOR platform because it simplifies developments, and improves user experience.
Add an argument to the Field, e.g.:
length = vkt.NumberField("Length", default=10, min=1, max=100, allow_empty=False)
When the field is empty, it renders similar to the min/max arguments, highlighting it as red, with the standard message that it requires to be filled.
  • raise UserError in code
  • InputValidation
  • on_next on next Step
Requested by
@miket
I really like the idea, it’s a lot more intuitive for users, especially new users.
We had the same concern. It seems to me if a user open a page and the first thing they see is a page filled with red parameters, it would be a little much.
I would suggest one (or more) of :
  • greying out optional parameters, or make a distinct visual for it
  • making required parameters red only if a view is trying to use them
  • another visual representation; eg, standard * (asterisk next to the field)
  • or even changing entirely how InputValidation is presented in the UI
