SDK: v13.3.0
Platform: v22.08.5
Python: v3.10
Isolation mode: docker
Setting the flex value of an OutputField does not widen the field, but the next field is at the correct location. In the picture the OutputField “Eigen gewicht vloer” has the same flex-value as the NumberField “Waterdruk tpv o.k. vloer” (flex=50). The other four fields are also OutputFields and have the correct width (flex=25)
I expect the flex of an OutputField to behave as the flex of a NumberField.
