I keep getting the error: AttributeError: ‘FileResource’ object has no attribute ‘get_content’
How do I resolve it?
from viktor.parametrization import ViktorParametrization, FileField
from viktor.views import PlotlyView
import plotly.graph_objs as go
import numpy as np
file = FileField('Upload Numbers', file_types=['.txt'])
label = 'Rainbow Plot'
@PlotlyView('Plot', duration_guess=1)
def get_plot(self, params, **kwargs):
file_content = params.file.get_content().decode('utf-8')
numbers = np.array([float(line.strip()) for line in file_content.splitlines() if line.strip().isdigit()])
# Generate a rainbow plot using Plotly
colors = ['hsl(' + str(hue) + ', 100%, 50%)' for hue in np.linspace(0, 360, len(numbers))]
data = [go.Bar(x=list(range(len(numbers))), y=numbers, marker=dict(color=colors))]
layout = go.Layout(title='Rainbow Plot of Numbers', xaxis=dict(title='Index'), yaxis=dict(title='Value'))
fig = go.Figure(data=data, layout=layout)
return fig
Hi Toufique,
The FileResource class doesn’t have a get_content() method, see the documentation for more information.
To access the VIKTOR File object from the FileResource call file property. To access the contents of the VIKTOR File object you can use getvalue() or getvalue_binary()
In your code this would look like the following:
import numpy as np
file_content = params.file.file.getvalue('utf-8')
return fig
Thanks, this helps! I made further modifications to the code as well and now it is running alright!
