FileField behaviour for upper-/lowercase file extensions
SDK: v13.1.0
Platform: v22.04.0
When uploading a file using a FileField with a file restriction, it doesn’t matter whether the file extension contains uppercase letters or not (e.g.: if the file restriction is “.geojson” it doesn’t matter if the file that will be uploaded has the extension “.GeoJSON”). However, when opening the drop-down menu of the FileField the upper-/lowercases do matter. So, in my example I am able to upload the .GeoJSON but I’m unable to select it in the drop-down as it’s looking for files that end with “.geojson”.
Both the upload and drop-down aspect of the FileField should have similar behaviour: both case-sensitive or not at all.
Hi Martijn,
Thank you for reporting. We already had this on our radar and we are working on a fix in the current sprint.
