Feedback on Viktor Docs
Originally i found a very small mistake in the docs, wanted to mention it to you to improve it.
In the docs, on the SummaryItem on the suffix item, the description says that the prefix will be put behind… this should suffix.
But then i wanted to report this in the feedback form on the site ‘Was this page helpfull’, but the text allowed is way to small for decent additional descriptions.
This will limit amount of feedback options for the user which is a bad thing imo.
Hi Johan,
Thank you for writing up this post. I will make sure the typo is addressed. I agree with you that character limit is quite strict. Unfortunately, this is a limitation of the system we use to gather the feedback. Therefore, I chose to limit it strictly rather than having the user fill in more context and only receiving the truncated message. It is something I want to address when we iterate on this feedback functionality though :slight_smile:
When this is a limitation of the used system, then this is indeed the best implementation of it.
This is better than ‘losing’ half your message.
But indeed, address it, more text would be usefull!
Thanks
