excellent question @jochem
the geometry module has been created to make very simple geometries and does not support boolean operations. there are however 3rd party packages that do it and that you can use in a VIKTOR app. in particular CADQuery is a good fit for this.
make sure you list an external dependency in the viktor.config.toml file:
packages = ["libgl1"]
app.py:
from viktor.parametrization import ViktorParametrization, NumberField
from viktor import Color
from viktor.geometry import Group, LinearPattern, SquareBeam, Material
from viktor.views import GeometryResult, GeometryView, ImageView, ImageResult
from viktor.core import File
import cadquery as cq
from pathlib import Path
import warnings
warnings.filterwarnings("ignore", category=UserWarning)
warnings.filterwarnings("ignore", category=DeprecationWarning)
length = NumberField("Length [mm]", default=30)
height = NumberField("Height [mm]", default=40)
bearing_diam = NumberField("Bearing diameter [mm]", default=22)
thickness = NumberField("Thickness [mm]", default=10)
padding = NumberField("Padding [mm]", default=8)
fillet = NumberField("Fillet [mm]", default=2, num_decimals=1, step=0.5)
def generate_assembly(params):
assy = cq.Assembly()
(length, height, bearing_diam, thickness, padding) = (params.length, params.height, params.bearing_diam, params.thickness, params.padding)
body = (
cq.Workplane("XY")
.box(length, height, thickness)
.faces(">Z")
.workplane()
.hole(bearing_diam)
.faces(">Z")
.workplane()
.rect(length - padding, height - padding, forConstruction=True)
.vertices()
.cboreHole(2.4, 4.4, 2.1)
.edges("|Z")
.fillet(params.fillet)
assy.add(body, color=cq.Color(1, 0.27, 0.0), name="body")
return assy, body
GLTB_PATH = Path(__file__).parent / "output.gltb"
SVG_PATH = Path(__file__).parent / "output.svg"
label = 'My Entity Type'
@GeometryView("Geometry", duration_guess=1, x_axis_to_right=True)
def get_geometry_view(self, params, **kwargs):
assy, _ = generate_assembly(params)
cq.occ_impl.exporters.assembly.exportGLTF(assy, str(GLTB_PATH), True)
return GeometryResult(File.from_path(GLTB_PATH))
@ImageView("Drawing", duration_guess=1)
def create_result(self, params, **kwargs):
_, body = generate_assembly(params)
cq.exporters.export(body, str(SVG_PATH))
return ImageResult(File.from_path(SVG_PATH))
This is the resulting view:
let me know if this works
