As a developer I want to be able to show a value (OutputField) in a row of a DynamicArray based on another value in the same row.
Currently, RowLookupis only supprted (and evaluated) in the context of min, max and visible(although I’m not really sure about the last one!).
An OutputField accepts RowLookup directly as a value argument, but not as an argument to FunctionLookup.
array = DynamicArray('My array')
array.param_x = NumberField('X')
array.param_y = OutputField('Y', value=RowLookup(param_x)) # This is possible
array.param_z = OutputFiled('Z', value=FunctionLookup(add, RowLookup('param_x'), 2) # This is not possible as RowLookup() does not get evaluated before being passed to the add function
I think this is relevant for the VIKTOR platform because this functionality already exist for normal Lookup. RowLookupis the equivalent of Lookup in the context of a DynamicArray .
Given the many advantages of DynamicaArrayit’s only logical to have the same functionalities for RowLookup as well.
One option is forRowLookup to be accepted and evaluated as an argument to FunctionLookupso that OutputFiled can have its value dynamically set based on values in the same row of a DynamicArray just like the example above.
Another option is always accepting “$row” in Lookup just like this example from the documentation:
_show_y = DynamicArrayConstraint('array_name', IsTrue(Lookup('$row.param_x')))
Last option (easy to use, but more work to implement) is to pass the row index as kwargs to the Callable. For example:
def custom_log_function(params, row_index, **kwargs):
return np.log(params.array[row_index].param_x)
array.param_y = OutputField('Y', value=custom_log_function)
As far as I know, there are no workarounds now, but if there is one, I would love to hear that!
