Exiting because of an error: request returned 403
SDK: v14.2.1
Platform: v23.06.5
Python: v3.9.13
Isolation mode: venv
Not able to publish an app, however I have published this app several time but now it is giving me an error
403 error (topologictower app)
topologictower app record
The app should publish.
I have created an app, which works fine in development workspace but getting an error while publishing it.
Looking at the related post, I have checked my app Maintainers, it looks perfect.
I have uploaded app file on github repository if needed.
I would be grateful for any help.
Darshan
I will send you a DM
Hi, the same error happened to me. I can not either update my published app or publish a new app, while the maintainer seems correct. Any suggestion? thanks!
ERROR:
Hi Hao,
You hit a limit from our end to prevent abuse. You should be able to publish again.
Thanks, mate! Problem solved!
I seem to have the same issue. I want to publish a new app (which works perfectly in the development workspace), but I get error 403. I made some apps previously and archived them because I am no longer using them. Now it seems that I can no longer publish new apps.
William
Hi William,
I asked our infra team to look into it, will get back to you.
Hi William,
Similar as above you ran into a limit to prevent abuse. This has been reset, so you should be able to publish again.
