Exiting because of an error: could not determine Python version: exit status 103
SDK: v14.8.0
Platform: v0.33.5
Python: v3.9.13
Isolation mode: venv
When Running the command viktor-cli install I get the error:
despite the fact that python 3.9 is correctly installed and my path is correctly set up - running python app.py produces missing module error, but still runs the code.
The app installs correctly and I can resume work on the project
I saw a related issue where the problem was solved by reinstalling python not from the Microsoft store, but from the official installer - I tried that but it didn’t work, tried resetting the PC completely and reinstalling Windows, also didn’t work. I have attached screenshots for clarity - please let me know if there is more info needed! Thank you <3
Could you try running viktor-cli check-system and see what the result is?
Hi Daniel, here is the result:
system-check
:thinking: could you show me what the viktor.config.toml looks like?
viktor.config.toml:
# For all available configuration settings, please go to:
#   https://docs.viktor.ai/docs/create-apps/references/viktor-config-toml
app_type = 'editor'
# assets_path = 'assets'
# packages = []
python_version = '3.9'  # '3.9' | '3.10' | '3.11' | '3.12.2'
# welcome_text = 'welcome.md'
When I try to run viktor-cli start, I get the error:
Exiting because of an error: app is not (properly) installed
Hi Joshua, could you try to manually remove the venv directory that is present and reinstall the app?
That fixed the issue, thank you so much!
