Hi all,
Since the inception of the Excel app generator, there have been a surge of questions on other ways to use Excel within VIKTOR, most notably how to use Python to make changes to Excel sheets, but still use VIKTOR to do the calculations within Excel.
For this, I would like to dedicate today’s Snippet Wednesday to showing an example of using openpyxl, a Python library to read/write Excel files, to help you advance your Excel manipulation skills with Python, and leveraging the result in a VIKTOR app.
Snippet
Let’s start by presenting an example problem: I want to manipulate an existing Excel sheet, changing values of certain cells, that can be used later on in the process to calculate the results.
For this, I will be using openpyxl, so make sure to add this to your requirements.txt.
Fill spreadsheet
In the example, I will be changing two input: a single cell, and a table. Here is the snippet on how one can do this:
from io import BytesIO
from pathlib import Path
from typing import List, Dict
from openpyxl.reader.excel import load_workbook
def fill_spreadsheet(my_number: float, my_table: List[Dict]) -> BytesIO:
# Load your workbook
print("Load workbook...")
wb_path = Path(__file__).parent / 'spreadsheet.xlsx' # make sure to have the spreadsheet name changed
wb = load_workbook(wb_path)
# Select a sheet by name
sheet_name = "my_first_sheet"
print(f"Select sheet {sheet_name} and fill values....")
sheet = wb[sheet_name]
# Select a cell and assign a new value
sheet['B3'] = my_number # assign a value to the cell
# An example how to add values to a table
for row_nr, row in enumerate(my_table):
row_id = 10 + row_nr # the row that is filled is the location of the first row + the row number
sheet[f'A{row_id}'] = row['column_1']
sheet[f'B{row_id}'] = row['column_2']
sheet[f'C{row_id}'] = row['column_3']
sheet[f'D{row_id}'] = row['column_4']
sheet[f'E{row_id}'] = row['column_5']
sheet[f'F{row_id}'] = row['column_6']
sheet[f'G{row_id}'] = row['column_7']
sheet[f'H{row_id}'] = row['column_8']
# Save the workbook
print("Save workbook...")
excel_file = BytesIO()
wb.save(excel_file)
return excel_file
To summarize the snippet, here are the steps explained:
- A function is created with the two arguments:
my_number(a float) andmy_table(a list of dictionaries, with keys “column_1” to “column_8”) - The Excel sheet that will be manipulated is loaded using
openpyxl.reader.excel.load_workbook(in the example “spreadsheet.xlsx” is used) - The sheet which needs to be manipulated is then selected (in the example “my_first_sheet”)
- The cell “B3” is then filled with the
my_valuevariable. - The table, that starts in row 10, is filled with the
my_tablevariable. - The changed workbook is saved to a
BytesIOobject, and returned.
Compute results
Once you have values filled, you want the Excel sheet to be evaluated. For this VIKTOR’s SpreadsheetCalculation can be used. Here is the snippet:
from viktor.external.spreadsheet import SpreadsheetCalculation
def calculate_excel(excel_file: BytesIO):
sheet = SpreadsheetCalculation(file=excel_file, inputs=[])
print("Do calculation...")
sheet.evaluate(include_filled_file=True)
return sheet.result.file_content
In summary the following is done: a file is passed in the function as a BytesIO object, loaded into the SpreadsheetCalculation object, evaluated, and finally the results are returned.
Note: The spreadsheet should meet the requirements of the
SpreadsheetCalculation, which includes not having Macros, and having the spreadsheets “viktor-input-sheet” and “viktor-output-sheet” included in the Excel sheet.
Application
This can be incorporated in a VIKTOR application, where you can download the results, visualize the results as a PDF, or post-process it to incorporate in other processes. Here is a snippet of a VIKTOR application that:
- Downloads the evaluated Excel sheet through a
DownloadButton - Renders a PDF of the evaluated Excel sheet
- Visualizes the result of the table as a
DataView
from viktor import progress_message
from viktor.core import ViktorController
from viktor.parametrization import ViktorParametrization, NumberField, Table, TextField, DownloadButton
from viktor.result import DownloadResult
from viktor.utils import convert_excel_to_pdf
from viktor.views import DataItem, DataGroup, DataResult, PDFResult, PDFView, DataView
progress_message("Load workbook...")
progress_message(f"Select sheet {sheet_name} and fill values....")
# Save the workbook
progress_message("Save workbook...")
wb.save(excel_file)
return excel_file
progress_message("Do calculation...")
my_number = NumberField('My number', default=40)
table = Table('My table')
table.column_1 = NumberField('Column 1')
table.column_2 = TextField('Column 2')
table.column_3 = TextField('Column 3')
table.column_4 = NumberField('Column 4')
table.column_5 = NumberField('Column 5')
table.column_6 = NumberField('Column 6')
table.column_7 = NumberField('Column 7')
table.column_8 = NumberField('Column 8')
download_report = DownloadButton('Download report', method='download_report', longpoll=True)
label = 'My Entity Type'
def download_report(self, params, **kwargs):
"""The method that is triggered when clicking on the Download button with the method name `download_report`"""
memory_file = fill_spreadsheet(my_number=params.my_number, my_table=params.table)
excel_file = calculate_excel(memory_file)
return DownloadResult(file_content=excel_file, file_name="spreadsheet.xlsx")
@PDFView('Report', duration_guess=10)
def pdf_view(self, params, **kwargs):
"""Renders the PDF view."""
with BytesIO(excel_file) as f1:
pdf = convert_excel_to_pdf(f1)
return PDFResult(file=pdf)
@DataView("OUTPUT", duration_guess=10)
def visualize_data(self, params, **kwargs):
progress_message("Extract results...")
wb = load_workbook(filename=BytesIO(excel_file), data_only=True)
# An example how get values from table
data_item_list = []
for row_nr, row in enumerate(params.table):
value = sheet[f'I{row_id}'].value
data_item_list.append(DataItem(f'Data item {row_nr + 1}', str(value)))
data = DataGroup(
*data_item_list
return DataResult(data)
