Error when using ci-publish
Hi support!, when using ci-publish we are getting an error. Any idea if we’re missing something?
 ./viktor-cli ci-publish NAME # replace NAME with the actual name of the app
(Exiting because of an error: could not get registered app)
We have replaced NAME with the Name of the app and even with Full name but both give the same issue.
afbeelding
afbeelding
Hi Enrique,
We didn’t enable the publishing on the CI user by default, because not all developers in your company have publishing rights. We have just updated the rights on the CI user, so you should be able to give this another try now.
