Viktor-cli v0.14.0
It is not possible to start any Viktor application. This problem started when I updated the app to no longer use docker to connect to the server.
Hey Kevin,
Thanks for your reply, there was indeed a problem with the environment. I was able to make the switch to virtual environment, now the the app works fine.
Thanks for your help!
