SDK: v13.6.0
Platform: v22.11.0
Python: v3.10.8
Isolation mode: venv
A SVGAndDataResult
is generating an Exception about character encoding.
File "viktor_connector\connector.pyx", line 314, in connector.Job.execute
File "viktor\core.pyx", line 1839, in viktor.core._handle_job
File "viktor\core.pyx", line 1826, in viktor.core._handle_job._handle_view
File "viktor\views.pyx", line 2021, in viktor.views.View._wrapper
File "C:\DevOps\Python.ParametricDesign\RWZITank\app\tank\controller.py", line 117, in view_scia_analysis
return SVGAndDataResult(image=scia_svg_data, data=scia_data)
File "viktor\views.pyx", line 1441, in viktor.views.SVGAndDataResult.__init__
File "viktor\core.pyx", line 869, in viktor.core.File.from_data
File "viktor\core.pyx", line 849, in viktor.core.File.__init__
File "viktor\core.pyx", line 700, in viktor.core._DataFileManager.__init__
File "C:\Users\rkg\AppData\Local\Programs\Python\Python310\lib\encodings\cp1252.py", line 12, in encode
return codecs.charmap_encode(input,errors,encoding_table)
UnicodeEncodeError: 'charmap' codec can't encode character '\u2212' in position 46431: character maps to <undefined>
When I downgrade the @SVGAndDataView
into a @DataView
or a @SVGView
those views work fine. Seems to indicate both data parts in return SVGAndDataResult(image=scia_svg_data, data=scia_data)
are valid. And the error is induced when both views are combined within Viktor.
Maybe something similar as the SVGResult issue that was solved in SDK v13.6.0 is still present in SVGAndDataResult
