When using @ParamsFromFile, the name of the created entity automatically becomes equal to the filename. It would be nice if during upload it is possible to change this name. I ran into the following two use cases:
- The file extension is included by default. When visualising geffiles the .GEF extension can cause labels to overlap even though the extension adds no beneficial information to the user.
- When downloading .GEF files from the BRO they are often named something like CPT00000000000<gef_number>_IMBRO.GEF. In this name a lot of characters just produce noise and a name like CPT<gef_number> would make it more clear.
The only workaround is to add an API call that renames the entities but this call would need to be connected to a button since it cannot be added in the function to which the @ParamsFromFile decorater is used. I currently do not see a workaround that achieves what I want to achieve.
