DynamicArray defaults + OutputField
SDK: v14.21.0
Python: v3.11
Isolation mode: venv
Problem
I get a ParamNotFoundError when trying to have multiple defaults and an OutputField in a DynamicArray.
def sum_x_y(params, **kwargs):
    return [row.x + row.y for row in params.array]
    array = vkt.DynamicArray("Array", default=[{"x": 2, "y": 3}, {"x": 1, "y": 4}])
    array.x = vkt.NumberField("X")
    array.y = vkt.NumberField("Y")
    array.output = vkt.OutputField("X + Y", value=sum_x_y)
returns a ParamNotFoundError.
Workarounds
2 solutions exist:
  1. remove default=[{"x": 2, "y": 3}, {"x": 1, "y": 4}] and instead set default values directly to x and y:
    array.x = vkt.NumberField("X", default=2)
    array.y = vkt.NumberField("Y", default=3)
    But then only a single default value can be assigned per variable.
  2. move the OutputField to outside of the DynamicArray:
    def total_sum(params, **kwargs):
        rows = [row.x + row.y for row in params.array2]
        return sum(rows)
        output = vkt.OutputField("Total", value=total_sum)
    But then we cannot output values per row.
Conclusion
Is this a bug or un purpose? Would you know perhaps of other workarounds?
Hi Remi, good catch. We are looking into it.
:white_check_mark: Bug solved with Viktor CLI v0.44.03 (20/03/2025)
