Hi, I would like to request that the max and min options of the number field can be set dynamically based on output of another process.
In my case, I want the user to be able to sample the data in my plotylanddata view using the slider to determine at which level the information should be supplied for. The level will change based on ground levels at the project site which could have a large variation and I dont want the slider to be wide ranging. Rather better that the slider covers the range of levels for which the calculation has been completed for.
I envisaged this working like the option field where you can use another process to dynamically provide the different options but this did not work.
I think this is relevant for the VIKTOR platform because allowing things to be dynamic based on the inputs is highly desirable.
