Dynamic table columns
I would like to have a MultiSelectField that I can use to extend the table columns with.
For example I select “Design” so all columns tagged with design (in constants.py) will be added to the table.
Visibility isn’t possible to change in tables, so I tried to apply conditions in the parametrization, but I don’t know how to use Lookup or FunctionLookup to get the selected list from the user…
It is currently not possible to add/remove columns from the Table dynamically. We do have it on our radar as a feature request, but not with high priority.
You could add all necessary columns and let the user leave them empty (ignore their content in code) for certain combinations with the MultiSelectField.
Thanks, I will use different tables with visibility on/off instead. Not that dynamic, but with 4 versions it will work.
Requested by @adam_hood and co…
I have changed this thread to a feature request
Do you have an update for this request?
We really need a dynamic table where the columns are defined by the data.
Request by Shaik Taher Basha of Jacobs. His case wants to have the possibility to add columns based on a certain criteria. A solution would be to set the visibility of columns, were this possible.
