Hi VIKTOR team,
I would like to ask a question regarding downloading multiple figures in a zip-file, since I am working downloading images out of an stix file. For downloading the files as a zip, I have build a dictionary. However, when I want to download this zip file (code snippet #2), I encounter an error (code snippet #3). When I put a single figure as the DownloadResult (see first code snippet), my code works well.
This is my (shortened) method in the controller.
def export_stix_figure(params, **kwargs):
# import stix files
stix_file_resources: List[FileResource] = params.input_section.stix_files
# import figure extension
fig_output = params.figure_selection.field
fig_format = fig_output # in this case ['PNG']
# convert stix files into DStabilityModel()
# start dictionary
fig_zip: dict = {}
for (...): # loop through 1) all stix-files 2) all stages
# make fig
fig_plotly = go.Figure()
(...) # filled plotly figure
fig_bytes = fig_plotly.to_image(format=fig_format)
fig_name = f'{counter}.{fig_format.lower()}'
counter += 1
fig_zip[fig_name] = fig_bytes
# example zipped files
# DownloadResult(zipped_files={'my_file_1.txt': my_file_1, 'my_file_2.txt': my_file_2}, file_name="my_file.zip")
print(fig_zip.keys())
return DownloadResult(fig_bytes, fig_name)
# return DownloadResult(zipped_files=fig_zip, file_name='my_figures.zip')
# return DownloadResult(fig_bytes, fig_name)
The error I get is this:
dict_keys(['1.png', '2.png', '3.png', '4.png', '5.png', '6.png', '7.png', '8.png', '9.png'])
2022-07-18 14:58:57.970 ERROR : Exception is raised
File "viktor_connector\connector.pyx", line 400, in connector.Job.execute
File "viktor\core.pyx", line 1788, in viktor.core._handle_job
File "viktor\core.pyx", line 1783, in viktor.core._handle_job.non_view_result
File "viktor\result.pyx", line 112, in viktor.result.DownloadResult._serialize
File "viktor\result.pyx", line 119, in viktor.result.DownloadResult._serialize
NotImplementedError
Could you please help me? Thanks in advance
