Hi support,
If I install an application with viktor-cli install the application gives the following DepricationWarning:
he application has successfully been installed. Use the command 'viktor-cli start' to start your app.
(venv) PS C:\Users\bavo6\PycharmProjects\HI-BetondoorsnedeApplicatie> viktor-cli start
C:\Users\bavo6\PycharmProjects\HI-BetondoorsnedeApplicatie\venv\Lib\site-packages\viktor_connector\_vendor\websockets\legacy\__init__.py:6: DeprecationWarning: websockets.legacy is deprecated; see https://websockets.readthedocs.io/en/stable/howto/upgrade.html for upgrade instructions
warnings.warn( # deprecated in 14.0 - 2024-11-09
2025-03-12 10:57:40.120 INFO : __ __ __ __ __
2025-03-12 10:57:40.120 INFO : \ \ / / | | | |/ /
2025-03-12 10:57:40.122 INFO : \ \ / / | | | ' /
2025-03-12 10:57:40.122 INFO : \ \/ / | | | <
2025-03-12 10:57:40.122 INFO : \ / | | | . \
2025-03-12 10:57:40.122 INFO : \/ |_| |_|\_\
2025-03-12 10:57:40.122 INFO : _______ ____ _____
2025-03-12 10:57:40.122 INFO : |__ __| / __ \ | __ \
2025-03-12 10:57:40.122 INFO : | | | | | | | |__) |
2025-03-12 10:57:40.122 INFO : | | | | | | | _ /
2025-03-12 10:57:40.122 INFO : | | | |__| | | | \ \
2025-03-12 10:57:40.122 INFO : |_| \____/ |_| \_\
2025-03-12 10:57:40.122 INFO : VIKTOR connector : v6.1.1
2025-03-12 10:57:40.123 INFO : VIKTOR CLI : v0.44.2
2025-03-12 10:57:40.123 INFO : VIKTOR SDK : v14.1.0
2025-03-12 10:57:49.446 INFO : Connecting to heijmans.viktor.ai...
2025-03-12 10:57:49.738 INFO : Connection is established (use Ctrl+C to close)
How can I resolve this warning?
