Hey there,
I have a problem while installing the viktor demo app.
Here is the Error-message with some context:
Successfully installed pip-23.3.1
Looking in indexes: https://sys.viktor.ai/api/v1/packages/
Ignoring numpy: markers ‘python_version < “3.8”’ don’t match your environment
Collecting viktor-connector==5.21.0
Downloading https://viktor-system.s3.amazonaws.com/packages/viktor-connector/viktor_connector-5.21.0-cp311-cp311-win_amd64.whl?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIA53GKZRCUAHO7GC7K%2F20231128%2Feu-central-1%2Fs3%2Faws4_request&X-Amz-Date=20231128T130110Z&X-Amz-Expires=300&X-Amz-SignedHeaders=host&X-Amz-Signature=db0436d44f834070f56368c9658f9fe160ddf12a8ed0c0575093ab3b26670fa6 (554 kB)
---------------------------------- 534.0/554.4 kB 419.0 kB/s eta 0:00:01
ERROR: Wheel ‘viktor-connector’ located at C:\Users\ms\AppData\Local\Temp\pip-unpack-ha8ctvg6\viktor_connector-5.21.0-cp311-cp311-win_amd64.whl is invalid.ERROR:
Exiting because of an error: installation of the app failed
I also executed the check-system:
V Operating system internet access
V Operating system access to PyPi
V Operating system access to VIKTOR system
V Operating system access to VIKTOR environment
V Python is installed correctlyThe system check has been completed with the following conclusion:
V Your system is ready to use VIKTOR with isolation mode ‘venv’
Thanks you for your help!
Edit: This doesn’t happen to the demo-App only but for all apps.
