Default filter App store - Verified Apps only
Currently the default view is:
This results in showing a lot of apps that are not supposed to be seen. (Niet geverifieerde apps).
The default in our case should be Geverifieerd. Not “Alle apps”.
Besides the default sorting is based on most used.
This means the same apps are always on top.
It would be better to allow the admin to define the default sorting.
And third.
The A-Z is not working. IT sorts on the registered app name. Not on the label (visible to the user).
It should filter based on the Label. Not on the registered (invisible) app name.
Nice feedback!
On the 2nd point, how would you like to sort the apps differently?
Tagging @mslootweg
I think in our case default A-Z would be the most logic. But based on the label of the app, not the registered name.
Hi @Johan_Tuls , thanks for catching this one. We are expected to release a feature today that will enable organizations to hide applications that are in the AppStore. This will give more control to govern apps the way you would like to see apps presented.
This is part of our greater theme to improve App Governance on the platform.
But to your specific points, we will be looking into these.
