Default camera settings for GeometryView
Hello,
I was wondering about the possibility of modifying the default camera settings for the GeometryViewer. The viewer seems to be inconsistently zoomed when rendering gltf models as it is either starting off very close or very far from the model which requires a lot scrolling or clicking the ‘center camera’ button.
Ideally, the solution would be a starting viewing position with x,y,z coordinates that is looking at (0,0,0). Additionally, being able to set these camera settings as well when initializing the viewer would be very helpful.
Thank you
@Leonard_Bonnet FYI
Hello
Can this also be applied to the IFCView?
It would be great if the model could be made to fit in the view by default.
