I created DStabilityModel using Geolib 2.6.0, I installed the worker from Viktor (v5.9.0) and installed D-Stability 2024.02.
When I try to run the analysis with the worker, D-Stability opens and my model opens. However, it does not seem to run the calculation and the Info message “External analysis not yet finished, waiting X seconds to retry…” just continues till time out.
When I press calculate myself, it does run the calculation in D-Stability. Therefore, the worker should give more than just run till time out. Is this a known issue and is there a fix to get more information about what is going wrong?
D-Stability opens, but does not start calculation.
Analysis in VIKTOR apps times out
The following, with manual intervention, does work:
trigger D-Stability analysis from VIKTOR app
Manually press calculate
Analysis completes and result is shown in VIKTOR app
What version of D-Stability did you select when installing the worker? There is a specific ‘console’ version that should be used to run headless analyses
Step 4 of manual intervention is not the case. But that does not matter, I indeed made the mistake of not selecting the console version, because I changed versions of D-Stability some time ago and selected the normal file.
