As a developer I want to create a workflow where entities can only be created through a workflow defined by the code, therefore it should not be possible to intervene with this workflow by creating an entity through the button that is available by default.
This will result in more user-friendly applications, and more robust.
A possible solution would be to add an argument on the ChildEntityManager, that would disable the the “Create entity” button. Or to disable the button on the Controller through a class variable.
None
Context
I’m creating an application where segments of a model are created. These segments are created based on a line, and fixed segment distance. Clicking on a button, all the section entities are created automatically. If the user clicks on the “Create entity” button, it would create an entity that would be useless.
