Here is also the system check output:
PS D:\viktor\topologicpy103> viktor-cli check-system --verbose
Starting VIKTOR system checkā¦
Executing curl -v -I --fail http://neverssl.com --max-time 5:
- Trying 34.223.124.45:80ā¦
- Connected to neverssl.com (34.223.124.45) port 80 (#0)
HEAD / HTTP/1.1
Host: neverssl.com
User-Agent: curl/7.83.1
Accept: /
HTTP/1.1 200 OK
Date: Wed, 05 Apr 2023 07:00:13 GMT
*Server: Apache/2.4.55 ()
Mark bundle as not supporting multiuse
< HTTP/1.1 200 OK
< Date: Wed, 05 Apr 2023 07:00:13 GMT
< Server: Apache/2.4.55 ()
Upgrade: h2,h2c
< Upgrade: h2,h2c
Connection: Upgrade
< Connection: Upgrade
Last-Modified: Wed, 29 Jun 2022 00:23:33 GMT
< Last-Modified: Wed, 29 Jun 2022 00:23:33 GMT
ETag: āf79-5e28b29d38e93ā
< ETag: āf79-5e28b29d38e93ā
Accept-Ranges: bytes
< Accept-Ranges: bytes
Content-Length: 3961
< Content-Length: 3961
Vary: Accept-Encoding
< Vary: Accept-Encoding
Content-Type:< Content-Type: text/html; charset=UTF-8
V Operating system internet access
Executing curl -v -I --fail https://files.pythonhosted.org --max-time 5:
- Trying 199.232.57.63:443ā¦
- Connected to files.pythonhosted.org (199.232.57.63) port 443 (#0)
- schannel: disabled automatic use of client certificate
- ALPN: offers http/1.1
- ALPN: server accepted http/1.1
HEAD / HTTP/1.1
Host: files.pythonhosted.org
Accept: /
HTTP/1.1 200 OK
Connection: keep-alive
*Content-Length: 1853
< HTTP/1.1 200 OK
< Connection: keep-alive
< Content-Length: 1853
Co< Content-Type: text/html
Server: nginx/1.13.9
<Accept-Ranges: bytes
< Age: 0
X-Serv< X-Served-By: cache-iad-kiad7000029-IAD, cache-lon420095-LON
X-Cache: HIT, MISS
<X-Cache-Hits: 31, 0
X-Cache: HIT, MISS
< X-Cache-Hits: 31, 0
X-Timer: S1680678014.745220,VS0,VE77
< X-Timer: S1680678014.745220,VS0,VE77
< Strict-Transport-Security: max-age=31536000; includeSubDomains; preload
X-Frame-O<pti X-Frame-Options: deny
ons: deny
X-XSS-Protection: 1; mode=block
<X-Content-Type-Options: X-XSS-Protection: 1; mode=block
< X-Content-Type-Options: nosniff
nosniff
X-Permitted-Cross-Domain-Policies: none
<X X-Permitted-Cross-Domain-Policies: none
< X-Robots-Header: noindex
V Operating system access to PyPi
Executing curl -v -I https://sys.viktor.ai --max-time 5:
- Trying 52.57.54.157:443ā¦
- Connected to sys.viktor.ai (52.57.54.157) port 443 (#0)
- ALPN: server did not agree on a protocol. Uses default.
HEAD / HTTP/1.1
Host: sys.viktor.ai
Accept: /
HTTP/1.1 404 Not Found
Content-Length:* Mark bundle as not supporting multiuse
< HTTP/1.1 404 Not Found
< Content-Length: 179
179
Date: Wed, 05 Apr 2023 07:00:14 GMT
<Referrer-Policy: strict-origin
Strict-Transport-Security: max-age=600; includeSubDomains
< Date: Wed, 05 Apr 2023 07:00:14 GMT
< Referrer-Policy: strict-origin
< Strict-Transport-Security: max-age=600; includeSubDomains
X-Frame-Opt< X-Frame-Options: SAMEORIGIN
ions: SAMEORIGIN
X-XSS-Protection: 0
<Connection: keep-alive
X-XSS-Protection: 0
- Connection #0 to host sys.viktor.ai left intact
V Operating system access to VIKTOR system
Executing curl -v -I https://cloud.viktor.ai/ --max-time 5:
- Connected to cloud.viktor.ai (52.57.54.157) port 443 (#0)
HEAD / HTTP/1.1
Host: cloud.viktor.ai
Accept: /
HTTP/1.1 200 OK
- Mark bundle as not supporting multiuse
< HTTP/1.1 200 OK
Cache-Control: no-cache
<Content-Length: 1276
< Content-Length: 1276
Date< Date: Wed, 05 Apr 2023 07:00:14 GMT
ETag: ā64142c32-4fcā
<Last-Modified: Fri, 17 Mar 2023 09:00:34 GMT
< Last-Modified: Fri, 17 Mar 2023 09:00:34 GMT
Strict-T<ransport-Security: max-age=600; includeSubDomains
X< X-Frame-Options: SAMEORIGIN
X<-XS X-XSS-Protection: 0
S-Protection: 0
- Connection #0 to host cloud.viktor.ai left intact
V Operating system access to VIKTOR environment
V Python is installed correctly
The system check has been completed with the following conclusion:
V Your system is ready to use VIKTOR with isolation mode āvenvā
