Can I use viktor to upload a image file, visualize it in the controller, and then load it into rhino for more processing in grasshopper?
Hi @ariaaaa,
As you might have already encountered, uploading images into VIKTOR is quite easy. You will also need to make sure you have a generic worker and that you add the image to the config so that the worker (which has Rhino & grasshopper). Then if you take a peek at the rhino/grasshopper tutorial we see that you need to activate the grasshopper script using python and I think you will need to load the image into rhino from there!
Hope this helps!
Kind regards,
Thomas
