BUG: Empty SiblingEntityOptionField in dynamic array is not included in parametrization
SDK: v14.8.0
Platform: v24.03.2
Python: v3.11
Isolation mode: venv
Normally when you leave a field empty, in this case a SiblingEntityOptionField it would be included in the params with a value of None.
Now when I include the SiblingEntityOptionField in a DynamicArray the key is not in the params anymore which results in an AttributeError. This feels very inconsistent (and unexpected).
current workaround is catching the AttributeError.
Consistent behaviour and the key should be always included in the params/
EDIT:
This behaviour seems to be only happening on the initial run: so after initializing the Entity. If you fill in a SiblingEntityOptionField and after that delete it the behaviour is as expected.
Hi Wichard,
This indeed seems to be a bug, thank you for notifying us! I’ve added it to our internal Bug tracker; we’ll use this post to keep you informed on the progress.
Kind Regards,
@kvangiessen This morning I ran into this issue again. Either the issue is back, or has never been resolved. Can you give an update?
Hi Wichard,
Looking at our internal tracker it seems it has not been prioritized yet, most likely since there is a relatively easily workaround available (e.g. params.array.get("sibling_entity", None) or a try: except AttributeError: as you mentioned).
I will quickly discuss internally to check if it makes sense to pick this up soon, or bundle it with other fixes for the DynamicArray.
Hi Wichard,
I have currently planned to investigate this in the upcoming sprint, which starts next week.
Kind regards,
Hi Wichard.
We have found the problem and implemented a potential fix for this. I expect this will be included in the platform release of next week.
Kind regards,
Hi Wichard,
The fix was shipped yesterday. Please let me know if this doesn’t solve your problem.
Kind regards,
