SDK: v13.7.0
Platform: v22.12.2
Python: v3.10
Isolation mode: venv
Problem at publish where cli gives a ‘Missing SDK version in requirements’. Last version was given as seen on these printscreens.
Published app with no problems or errors.
Publish from local terminal.
ci-publish gave exactly the same problem.
Hi Enrique,
I think you forgot to add the # before the viktor version, so in this case it would be:
# viktor==13.7.0
plotly==...
See: Upgrade SDK Version
Does this solve your problem?
My bad, common case of assumptions that don’t work. I thought that the hashtag wouldn’t be necessary anymore since version 13.7.0. This off course solved the problem. Thanks Kevin!
BTW= removing the hashtag works just fine on the development environment.
maybe nice to add: we are working on enabling this through the complete flow and no longer necessitating the leading hashtag. we will communicate when this is supported an update the documentation to reflect this
