BLOG: Export and Visualize ETABS Model Results 🚀
If you’re a structural engineer working with ETABS, you might recognize the struggle of exporting and processing analysis results efficiently.
In this blog, Alejandro Duarte Vendries helps you fix this by creating a user-friendly web app that seamlessly connects with ETABS!
The blog contains 2 examples of how you can export and visualize results from ETABS more easily. Follow along with all the steps and you’ll end up with an app that:
:white_check_mark: Enhances collaboration
:white_check_mark: Simplifies data export, visualization, and sharing
:white_check_mark: Minimizes manual errors
Read it here!
