I am using GeoLib to run DFoundations analysis. I can create and run a model, and the output file looks as expected. I am looking for the best way to retrieve the information in python to create a bearing capacity plot for my app.
I am using the dedicated parser included in the SDK, as described here: D-Foundations | VIKTOR Documentation
Using this, I do get a parsed output, however, it takes so long that at first I thought my terminal got stuck. I am running a simple analysis with only one pile, the simulation itself takes about 3 seconds, so there is no reason the parsing should take over 2 minutes.
Furthermore, the output I do get is quite simple. For instance I get the PPN, the and the MaxShaft Forces, but nothing like a force for each depth. What would be an alternative approach?
What is the size of the output file?
In the worst case, without filtering to reduce the number of soil layers it is 99,8 KB, I have no clue if that is big or small. But I expect that is too big then?
Hmm, when I do filter the soil layers, and only leave 6, I have a file of 82,0 KB, so the difference is not that big
That is small. Big would be in terms of MB.
The DFoundations OutputFileParser
could be optimized quite a bit. I was thinking that you are probably near the memory limit but that should not happen with such a small file. To be sure, could you check out the memory usage when performing the parsing? This can be inspected by using docker stats
in a second terminal.
My memory usage seems fine (hovering around 50%) however my CPU usage goes up to 105-110% so I expect that the problem is there
I wasn’t able to reproduce the problem with @Puijterwaal (parsing took 2 seconds with the provided test files).
