Hi, I’m getting the following error when trying to start up our app:
2022-01-10 15:35:26.012 INFO : VIKTOR connector v5.1.2
2022-01-10 15:35:26.012 INFO : VIKTOR SDK v12.6.0
2022-01-10 15:35:26.012 INFO : Loading app…
2022-01-10 15:35:27.952 WARNING : /usr/src/packages/yaml/constructor.py:126: DeprecationWarning: Using or importing the ABCs from ‘collections’ instead of from ‘collections.abc’ is deprecated since Python 3.3,and in 3.9 it will stop wo
rking
if not isinstance(key, collections.Hashable):Traceback (most recent call last):
File “”, line 1, in
File “src/connector.pyx”, line 669, in init connector
File “src/connector.pyx”, line 570, in connector.load_manifest
File “src/connector.pyx”, line 517, in connector.load_manifest._preprocess_entity_types
File “viktor/core.pyx”, line 1532, in viktor.core._handle_job
AttributeError: ‘GEFController’ object has no attribute ‘views’
I have tried the following:
- Go back to a version that I am certain works (from last week), clear the CLI, install. Even this version gives the same error.
- Start a different app (in fact, the spreadsheet tutorial app). This works. In fact, both the version that ended up not working and the version I know works, work on my coworker’s machine
- Restart computer, reinstall
- Clear the CLI, restart computer, reinstall
- Delete the related Viktor-Install directory, clear the CLI, reinstall
The only thing I realistically changed when installing (right before I started getting the error) was the import of another python package through the requirements file, but I am not sure if this is related. This requirement has since been removed.
I am also getting the following line in my Ubuntu terminal on startup, of which I also don’t know if it’s related:
-bash: /home/ron/.bashrc: line 118: syntax error near unexpected token
(' -bash: /home/ron/.bashrc: line 118:export PATH=/home/ron/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/usr/lib/wsl/lib:/home/ron/viktor-apps/
